I cant figure out what to do next. I recently purchased a 85 30hp Johnson Outboard. It ran great the first few times I used it. However I notice it was not discharging water out of the water pump (pee hole) so I had the impeller replaced by a professional shop. After I got the motor back and went to use it. I noticed that when I put it in gear and throttled it up there was no power to the prop. It pushes the boat along like it is dragging an anchor. The motor idles fine and runs and revs up in neutral. Some one suggested bad gas so I replaced the fuel and hose. The engine seems starved for fuel when it is in gear and throttled up. Any suggestions before I take it back to the shop? Would cleaning out the carburetor help? Or Could this be a spark plug problem? Thanks
