Re: 85 Johnson Javalin coughing
It is common for the engine to have a "lean sneeze" when first started each day and the engine is cold. Once the engine reaches normal operating temps, the sneezing should go away. If yours still does this, it is an indication that the engine is running lean and that one or more of the small idle passageways in the upper carb body may have some dried fuel restricting the flow somewhat. Carb overhauls may be needed.
