85 Merc 115 inline outboard electrical problem
Dmunch
Top cylinder not firing. All the other 5 are. The ignition coil and wire on top cylinder are good. What the next possible problem....Stator, trigger plate or one or both of the switch boxes?
Faztbullet
Re: 85 Merc 115 inline outboard electrical problem
If one cylinder is not firing its usually a bad switchbox, swap positions of boxes and see if problem follows....
Dmunch
Thanks, I will see if that works
Dmunch
To swap the boxes, can I swap the red & red/ white and blue & blue/white wires?
Faztbullet
just flip trigger leads, the # 6 cylinder should not fire , engine will not start as firing order is reversed
Dmunch
I flipped the power leads and the top cylinder is still not firing. Is it a bad switchbox or stator?
Dmunch
Just so I have this right and don't waste a bunch of money, I swapped the blue, red and black wires. Is that right or are the power leads the brown wires?
