I recently traded for an 85 Mercury 25hp 2 stroke that isn't running quite right. Basically it idles OK, but when you start to rev it up, it tends to bog down and sounds like it isn't hitting on both cylinders. Then, for no reason, it will kick back in and take off, then bog back down. For some reason it will not stay up to full throttle. When it does stay full throttle, look out, cause it pushes my 16' jon like a bat outta hell.<br /><br />What could be the problem here? I tried two seperate fuel lines with the same results and the gas is fresh and properly mixed. Any help is greatly appreciated.<br /><br />For what it's worth, I know very little about outboards, but have some buds that can help out if we can locate the problem.
