85 Mercruiser carburator choke question
cedgo
Swapped '74 120hp Mercruiser for '85 140hp.
Carb on '85 has purple wire to choke which is absent on the '74.
Wiring harness from '74 is now on '85, but choke wire still present.
Question. What/where should the purple wire attatch?
eavega
Re: 85 Mercruiser carburator choke question
Purple wire is generally +12 V Ignition Switched. From my last adventures in Mercuiser, I know that the choke needs +12 V when the ignition is in the on/run position. The choke is closed when the ignition has been off for a while, and a bi-metal strip inside the choke control heats up with the ignition in the on/run position and eventually opens the choke.
In my motor, the purple wire to the choke control comes out of a wiring boot from the opposite side of the motor, and is attached to the coil resistor wire as well as the alternator.
Rgds
cedgo
Thank you eavega.
