64osby
- Jul 28, 2009
- 6,826
I have a Johnson V90, 1985, Model J90MLCOS, with VRO.
I've had the boat about 3 weeks. It has run great. Today I took the boat out and did some tubing with the kids. After about an hour I had an alarm go off. Intermittent beep about every 3 or 4 seconds.
I stopped and popped the hood and the #3 plug was loose and leaking oil and the cooling hose to the port side had broken plastic clamps. I Zipped tied the hose and tightened the plug. I was able to run back slowly to the launch the alarm popped back on and I shut her down, waited and idled back in.
After I brought it home I took this pic, It had leaked a little oil from the loose plug.
At home, hooked up the muffs and checked the compression, all cyl at 120 + 3. Water is flowing, but the alarm still goes on after about 2 minutes at idle.
I had bought a disk and pulled it out and the section on warning alarms and VRO has not been included.
Reading some of the search info it appears to be a VRO pump issue, I think???? The tank is about 1/2 full.
What am I looking at here? Thanks for any help.
