FAIRWEATHERBOATER
- Jul 3, 2002
- 10
I have an 89 Bayliner "L" drive that sat in the garage all winter until today. Because it is hard to start after so long, I pulled the plugs, dried them off, squirted WD-40 in, then just one shot of starting fluid before putting the plugs back in. The motor started, ran 15 seconds then seized up. (It was not running fast when it happened). It sounded like some of the rings broke, then jammed the cylinders. I realize the motor will have to be taken apart to be fixed, but I wonder if new rings can be put in without tearing the motor completely apart. I have a friend who is quite mechanical who can help. The boat repair shops are all swamped as usual.
