85hp evinrude
dalej
I bought this boat and it ran great the first four or five times I took it out but the last time I went out the boat it had little power-Motor seems to be running fine it just wont go over 10mph-It was doing over 40mph last week-
Spun prop ? Strechted throttle cable ? Bad compression ? HELP !!!
tashasdaddy
Re: 85hp evinrude
well you need to do some trouble shooting to rule the easiest out first. check your compression on all cylinders, and spark on all. record the results and post. did the fuel primer bulb get suck flat? model of year of the motor is always required, as there are many 85's. what do your plugs look like.
