bayliner33
- Jun 30, 2013
- 44
Well I got my 85hp force motor (1987) to run, and idles fine, but when I put it in gear forward or reverse it shut's off. I drained flushed and refilled the lower unit from the bottom up so there is no air in it. When I drained it there was no trace of water, or shavings. When in neutral prop turns freely. wondering if it is linkage problem, or internal. I did notice that the carb linkage does not move until you are 3/4 the way through forward throttle. maybe stalling out??
