85hp Force outboard can only get 2500 rpm's at WOT
jeffcool326
I'm pulling hair at this. I have a 85hp force outboard that has 150psi in all 3 cylinders, Good strong spark, and is getting gas in all 3 carbs. The boat will idle fine, go into gear fine, but when you got to WOT it max's the rpm's out at 2500. Any explanation would greatly greatly appreciated!!!! Thanks in advance!! Jeff
jeffcool326
UPDATE!!!!! It was the cdi boxes. I did a swap and it max's out a 5600rpm's........... THANKS TO THIS FORUM I WAS ABLE TO FIX IT BY GOING THROUGH SOME OLD POSTS!!!!!!!!!!!
jerryjerry05
Darn!! I was gonna suggest switching the packs!!!
Probably a bad connection or loose wire somewhere?
