collegefund
- May 5, 2009
- 8
HI eveyone, I have a '87 Bayliner '17 Trophy center console`with a 85 Force out back. I got the boat from a friend and he has owned it for years with the same problem.... The boat fires up and runs great, it has new plugs, 120 psi of compression, and spit shine carbs and ive ran some Seafoam thriugh it. Problem is it wont turn past 3300 RPM in the water (28 mph tops by myself), and i also have a problem with it stalling when I put it in gear if i dont quickly give it gas. In neutral it runs about 1100 and about 8 or 900 in gear once I keep it from stalling. The carbs are opening all the way and ive revved it to 5000 in the yard. The prop is pretty ate up from corrosion, the propeller reconditioning place said its probally a 17 pitch but it measured out to be about 16.... he also said that the prop is not why im not reaching max RPM. What do you think the problem is? Any help is GREATLY appreciated!
thanks,
George
thanks,
George
