My stator has 2 yellow outputs and 2 blue outputs with a plastic plug to each CD unit. The two blue ones are spliced together to make 1 robbing robbing the second CD unit of a blue output. Is that right? It's a 3 cyl. engine.
Secondly, how do you test the ohms resistence between them? Do i ground the black lead of the multimeter and test each wire with the positive lead or do i test them both at the same time?
