Hey RRitt or anybody.
I have a 1988 85hp Force with a trim issue. I keep running out of fluid, and it seems like it is squirting out from around the large ram of the trim piston. When it is full of fluid, the motor goes up/down just fine and seems to hold fine in the up position. Couple of questions....
1.) I am assuming that there is an o-ring or something inside that needs to be replaced?
2.) Is this a special order item or available at most hardware stores?
3.) What am I getting into if I disassemble this component? Are there all kinds of parts that are going to fall out
One other thing that I noticed.... several pictures that I have seen, the trim ram seems to have a rubber gasket on the outside, around the ram... mine doesn't have this. Is this an issue.
Also... are the screw/plugs available where you fill the fluid on the t/t motor housing?
Thanks for you help.
Geeco
Geeco
