1975 Evinrude 85 hp. I have been around the boat for years and it has been a reliable boat. A carb leak forced rebuilds for both carbs. Now the boat runs perfect when out of the water, it idles and raps right up when you give it throttle. When in the water, it only goes about 10 mph, but one time it just took off and ran like it should for a bit, and now it's back to it's sorry state. I have 125 psi compression on all cylinders. I was told there were recent spark plugs, but (when looking from the back of the boat forward) the right 2 plugs had some buildup on them and the rt 2 were perfectly clean. The butterflys open all the way at WOT, ummm, that's about as much as I know so far, any ideas?
