85hp looses fuel pressure
Ballsdeep1
my 85hp looses fuel if i open throttle all the way if i have a friend pump the ball it runs fine . is the problem in the ball or my engine i replaced the diaphram fuel pump and it didnt help :confused:
jerryjerry05
Re: 85hp looses fuel pressure
Either the check valve in the ball is bad or you have an obstruction in the vent line.Or their is an air leak in the line.Jerry
Ballsdeep1
i have two twelve gallon plastis tanks the vents are on the caps ill try replacing the bulb and check my connections. hope this solves this its been haunting me
