Hi Guys. I just posted a reply to a post by whipple about same situation as I have with a newly acquired 1975 (year Id by serial number)mercury 850 85hp. Had the water pump impeller replaced and the carbs rebuilt by a local shop. It ran with a stream from the telltale from the shop to my dock which was about 5 miles. I watched it carefully many times while going to the dock.When I restarted it at the dock about 45 minutes later no stream from the telltale, rather smoke that appeared to be same as the exhaust smoke. Maybe an occasional drip of a drop of water but few and far between. I have tried running a wire up the telltale. Still no stream. Blew air up telltale, then removed telltale hose and blew air in the telltale opening at the head. Got a stream after 10 seconds or so and stream only lasted 10-15 seconds. It is a problem to pull the lower unit as the motor is on my pontoon boat and I don't have a means to transport it back to the shop that did the work. They don't make service calls either. I'd sure appreciate some words of wisdom on what to do. Could it be the water pump is pumping ok and telltale has an obstruction? If so, is there any way to clear and correct this??? Please help! Clark
