'86 110hp V4 - Size & Length of Stator Bolts?
realboats
I was putting the stator back on my powerhead and felt I should double check something that looks odd to me. The stator was mounted with 2.75" long, 1/4-20 thread, 5/16 hex washer head (washer and hex head is one piece). It's easy to recognize these bolts because the small heads look a bit odd on a 1/4-20 bolt. The bolts also each have split lock washers on them. <br /><br />The parts catalog does not show the lock washers and doesn't specify the size of the bolts. I don't feel right about tightening these down on the stator and I'm wondering if they even belong there. Oh, and the stator part# is 583104. <br /><br />Can anyone tell me if the above bolt is the right size and type, and if lock washers should be used with it?<br /><br />Thanks!
DHPMARINE
Re: '86 110hp V4 - Size & Length of Stator Bolts?
You are right,the parts book doesn't show much.<br /><br />If this hardware was holding the last stator in place,I think I'd stay with it.And use Loc-tite.<br /><br />DHP
R.Johnson
Some of these 2.750 - 1/4-20 bolts also had a Allan socket head. Early stators were held down with a #10 screw with a phillips head. The 1/4 bolt locks down the stator much more securely, as DPHMARINE said use a drop of loc-tite.
