Re: 86 125 hp force outboard
Shift linkage rigging is ensuring that the L/U is in sync with the remote control. If neutral is selected, the L/U should be in neutral etc. To check, remove the shift cable from the shift lever at the power head. By hand, move the shift lever full forward while turning the prop. When fully engaged, with a felt marker, mark the shift rod level with the leg (just below shift linkage disconnect for L/U removal). Move the shift linkage to full reverse while turning the prop and mark the rod again. Make a third mark equidistant between the previous two. This is the exact mid-travel or neutral, from a mechanical perspective. Reconnect the shift cable, and with the remote in neutral, the middle line on the shift rod shoud line up to the point of reference. If not, adjust the neutral interlock lever with the two nuts until it does. As Foodfisher mentioned, it might be wise to cheat on the forward side a little.
