I currently own a 1986 regal boat with twin Mercruiser 4.3, I recently replaced one of my engines, but since then the new engines continues to overheat, I have replaced the lower unit impeller pump, engine water pump, have cleaned out the t-stat housing assembly, manifold risers, and removed the thermostat. At idle the engine runs between 200 and 240 degrees once i run up the rpms to 2200 it tends to cool off between 180 and 220, does anybody have any insight on this. <br /><br />Just a little insight; the other engine runs fine and doesn't have a thermostat <br /><br />Thanks
