I acquired a E40ELCDE, runs awesome EXCEPT the motor barely charges battery. If I idle and trol for extended periods the voltage on battery drops slowly (according to sonar). Only when I cruise around lake that I see voltage slowly increase on battery.
1. Battery is Good (new)
2. I replaced the recitifer with new one.
3. *****I get electrical interference when I try conecting volt meter to battery) gets worse the closer motor the voltmeter is.
I am suspecting faulty charge coil? anything else I should check?
