got the boat in the water/running with what i thought was fine. i was checking the engine and got a shock from the plug boot on the top cylinder. i used a spark plug light tester and the light didnt light.. i tried switching plugs to see if they were the issue but no light
i then tried switching them (im gonna call them coils-square box with wire)1 to 2 cylinder.. neither would light then
switched plugs to check - nothing
went home and grabbed a coil from a doner/broke engine - no spark
why would switching them kill power to both
i read online that theres a trigger switch under the flywheel that could be the issue
thanks in advance
thanks in advance
