Model: E10SELCDB
It ran fine then one day, no start.
Starter works, fuel pump is working.
Tested the spark with a tester, bought from autozone. Can't see anything.
So where do I begin? I want to test the ignition coils but I'm not sure how to do that. I have a multimeter, can I use that in some way to see if it is good. (both plugs aren't sparking).
Here are some pictures.
Ok, I'll start here. The killswitch is rotted. Not sure if this part is causing the no start.
Termninal Block
Stern
Ignition Coils and Starter
Bow
Thanks for the help. It's hard to pull in and out of the slip in a sailboat with no motor...
Termninal Block
Stern
Bow
