I know this may be a little bit of a pain and most may figure why bother but its killing me not knowing exactly what year my one 225 is on my Dixie. I've done a lot of exhausting research and I'm confident its either an 86 or 87. I have an 88 and it uses the type 2 CDI with single pack. The one I'm IDing has type 2 also but duel packs so its older. Everything i can find in print says the 225 replaced the 235 in 86. I've removed all electrics and connectors under the CDI as a lot of you had suggested to see if the model # was stamped in the block and it not there on either of my 225's. I was wondering did both the 86 n 87 run the VRO2 system an did they both have duel CDI packs. I figured if the 87 had a single like the 88 it would be an easy ID. If not any one have any other differences between the two you could suggest. Thanks
