86 bayliner capri stalls when shifted into gear
Stearns250
I got the boat to idle and rev in neutral but when I **** into gear it stalls out. The motor is a aq131a with a 44pa1 carb.
kenny nunez
You may need to clean the carburetor . They are easy to service and quite often no parts are needed if you are careful taking it apart. The idle mix screw should be 1.5 turns from seat.
Stearns250
Alright, i plan on running it this weekend in a 55gal drum to tune the carb, i just rebuilt it when i started having the problems. its been difficult to get this thing tuned. if it helps any i am in Arizona, would the altitude have any effect on the idle mix screw?
kenny nunez
The idle mixture screw will end up 1/4 either way of the 1.5 setting. Are you sure the points are good and adjusted along with the timing ? Is the compression even on all 4 cylinders ? The exhaust manifolds did have a problem with the #4 cylinder getting some water when they started to get rusted and had an internal leak.
