Re: 86 DT 115 Fuel Leak
Removed the Needle Valve assembly then carefully removed the pin. There was a bunch of black gunk around it. Cleaned that off and it slid back in the housing easily and slid back and forth easily.
Put everything back together and it runs like a champ without a leak..
What is the purpose of the small spring loaded piece at the tip? Seems like the float could just push on the large piece without adding that complexity.
