86 DT 115 oil/temp gauge
rockb
I have an 86 DT115. Oil and Temp gauge was working fine. Took it out to replace the console. Plugged it back in and now nothing.
There is a 5 pin plug and two separate wires. The plug is a no brainer. The two wires coming from the engine are red and Pink/Red. The wires on the gauge are red and brown. I am pretty sure that red went to red and the pink/red went to the brown.
Can anyone confirm this wiring or suggest anything else to check?
stylesabu
Master Chief Petty Officer
Re: 86 DT 115 oil/temp guage
check fuise under engine cover
rockb
Re: 86 DT 115 oil/temp gauge
The fuse is good.
Unplugged everything from the gauge and plugged it all back in and now the oil level lights are lighting up. I guess one of the connections was just loose.
