I hope someone can help me out here. I have an 86 Evinrude 25hp outboard. It was sitting quite awhile when I got it. It runs great, but overheats. I installed a new impeller with the key and a new thermostat. Blew out the copper water tube with an air compressor when I had the lower end off.
When running water just barely sprays out the exhaust hole even after the engine is warmed up - and my overheat alarm goes off in a few minutes. There is obviously not enough water flow.
When I put a hose down the thermostat hole water comes out everywhere. But, when a hose is connected via earmuffs over the water intakes there is no water coming out of the thermostat hole - Even when the engine is running with the thermostat removed. But, I do get water coming out of the rubber hose that is behind and to the left of the housing that covers the thermostat. I get water out the tell tale hole with either the earmuffs on or the motor in a can filled with water. Does anyone have any helpful suggestions on what to do next? Thanks for any help you can give.
