Island_oki2000
- Aug 31, 2009
- 79
I've been doing some work on my kicker motor. One thing the guy did that I bought it from was cut the kill switch wires so he could use an extension handle. I don't have the extension, so was looking at putting the wires back together at the throttle. I spliced som e wire in to make it fit then connected the two wires together. Problem is, both wires are same color, so I could not tell which wire from the throttle goes to the two wires coming from the handle. I guessed and it didn't work. Motor would not start. As soon as I cut the wires again, the motor started right up. SHould I just switch the wires or could the kill switch be bad?
