CaptRon29
- Mar 19, 2012
- 7
Hi there everyone names Ron!! Real excited i got my first (real) boat this year aside from my couple small aluminum fishing boats.. So I bought a 1971 Starcraft tri hull with a 1986 Force 50 hp and a 83 Merc 7.5 kicker and kick plate.. Both non running at time of purchase. I inspected everything including (dry) compression check on Force came up with 180 top and 165 bottom.. So not to bad since it sat from sometime in 2008 until a couple weeks ago.. So i offered this guy 300 bucks and to my surprise he agreed! So i get this puppy home and find a bad perko switch.. (Taking you all from square 1 so you know all the details sorry) I replace the battery with a large marine RV battery and direct connect it bypassing lights and acc... Engine is now cranking over on its own with no spark and the float bowl is leaking... I managed to slow the leak enough to make sure gas is getting in carb to fire, spark plugs were brand new from a previous guy who also looked at the boat, checked the coils and about everything i can see on outside with something that looked like positive and negative for continuity. All circuits seemed to be closed (good thing).. So than i get online and find out this thing has points! Holy **** batman i bet if i clean em up it will fire! So i get a puller get the flywheel off find the points and carefully take a 300 grit and gently abrase them. (did not check gaps) I stick everything back together and crank motor. ITS ALIVE! started up lickity split! Actually ran pretty good too since even the float bowl was still leaking. So first thing i do is take her down to the water and just wanna see how she does with a load right.. TO my surprise it gets up and plains with no hesitation for about 5 min than it just pukes. We do it again for about 5 min after adjust that timing rod thing attached with the throttle cable; there's a set screw adjustment i messed with. She gets up and takes off for about 10 min or so this time but again pukes out almost instantly. So I know she runs decent cool! Take it home next day go to marina get a gasket kit for float bowl including the 2 upper/lower rings around bolt. Install them and bingo no leak. Than i get new gas (premium) and add some synthetic evenrude/johnson 2 stroke oil.. heres the really awesome part.. my dumbass put 50-1 in the tank! I read it wrong and didn't realize till after i was cruising for about 10 min and it pukes out again except this time it dont wanna fire back up. I get a tow to shore get home lean the gas out with another gallon and pull plugs and crank it to get cylinders dry from access oil. I clean plugs up stick them in and now she wants to fire cool! I got it to run for a few sec than nothing but quick idle and shut off.. Hmm im thinking so i pull out the top plug and I crank the engine and boom she fires up! Ok so now im stumped why the heck? So i get online again and people talk about point gaps. Says use the flywheel timing marks 2 @ 180 degrees from each other and gap at .020 correct? Alright so again im new to this so from my understanding I have one mark with a red dash on it making me think thats primary. I turn to primary, take off the flywheel and check to see what point is open. I gap and set that one at spec than turn the the fly wheel to next mark and gap the other point. So now i have both points opening and closing opposite of each other at .020 gap. did i time it right? sure hope so... Than i go back to starting the engine and still same symptoms.. Runs off bottom plug but not top.. I actually have to take the top plug out of the head fore the engine to start! Why? So I dont want to give up and I don't have many tools along with money what should I do next? Can someone tell me exactly how to time this engine for dummies lol?
