Been chasing a high RPM miss for quite some time, checked everything possible electrical, stator, timer base, coils, wires, cdi boxes, shift switch, harness's for possible shorts, fuel tank, lines, vent, bulb etc... my dealer went through carbs last fall, all this and still the same, 3500 rpm and it starts missing and falls on its face, some days if lucky will get 4200rpm, last night I pulled the carbs and found 4 of 6 have cracks in the venturi tubes going from the bottom of the tube up past the tiny holes that are drilled in them, if I understand how these work they are drawing gas up out of the bowl on a vaccum , right ?? if their cracked their not getting the corrcet amount of gas. I'm in the process of rebuilding all of them, I have 6 carbs for parts and hopefully this is the fix, has anyone seen this and am I on the right track with this ?? THANKS in advance, really learn alot from this site, very lucky to have so many knowledgable people willing to share their time and expertise.
