86 johnson 9.9 water comes out hole but not pee hole in middle
tim thompson
Hi < I replaced water pump etc. and hooked hose to copper intake water comes out hole on r. side of motor underneath( tube feeds it from a small block.) no real water comes out pee hole. Is this a concern prior to reassembly? After reinstalling lower unit and testing does water come out of pee hole or is it some time till thermostat allows it? Thanks Tim
Daviet
Re: 86 johnson 9.9 water comes out hole but not pee hole in middle
To the best of my knowledge, water should come out of the tell-tale with a hose attached to the water tube. You should get water out of the tell-tale with the engine running within 10-15 seconds. The tell-tale is before the thermostat so it does not have to open before the tell-tale squirts water.
Rick.
Above post if right as rain. Sounds like the grommet at the top of the water tube may have collapsed (which blocks flow). With a garden hose and city pressure water should shoot across the room. Possibly water passages in the engine. You could pull the stat and try back flushing from there. A little history would help maybe. Best of luck. Rick.
