I have a 1987 Thundercraft with a 3.0 OMC 140 HP engine. I am trying to troubleshoot the carburetor problems. The boat has starting problems I have to crank for quite a while to have it started. In order to start I have also to adjust the screw so the engine get some RPMS and warms up. Then the engine idles nicely but when I hit the gas it bogs down immediately with a slight pop from the fire arrestor. It takes some slight back and forth movement for the engine to jump into higher RPMS and from then it flies with no problems until I stop and restart again. Do I have a carb issues or timing issues. Please throw me some bones here. Thank you.
