kstrafo@gmail.com
- Jul 6, 2016
- 8
1986 4.3l engine. motor will get up to around 3k rpm and it will go no higher. The motor will actually back itself down. If I let it sit for a few minutes it will do the same thing. I have gone through most of the usual attempts to remedy situation and everything I try results in the same situation. Heads were replaced, new coil, new ignition mod, timing seems to be ok. getting fuel. New plugs, new fuel filter. About to replace motor but want to make sure its the engine. Not original engine, engine replaced in 2000. Thanks for any help!
