This boat has been in the family (mostly my Dad) since he bought it new in '86. I was the last to get it, about 5 years ago and turned it into a project with my son. We tore out all the plywood and seats and reinstalled new exterior plywood, carpet and seats. The back-to-back seat that folds out into a lounge was my feable attempt to get my wife into boating, it failed :blue: Anyway, we were on the lake last weekend and after a couple hours of fishing, my son pointed out that we were taking on water. It was clearly the most water I had ever seen in the boat and immediately turned the bilge on, which pretty much kept it at bay but was not lowering the level of water. I decided not to take any chances and headed back to the dock. Before we headed home, a boat repair guy was there and mentioned he thought there was too much play in the transom and that it was probably leaking and needs replaced. I would also have to do a leak test via filling the boat up with water and looking for a leak from under the boat while it sits on the trailer. (You will see that the inside of the boat is covered with plywood/carpet)
After looking at the transom, you will see that it has been cut down even further and that one side has an open area with direct access to the edge of plywood making up the transom. I've never done leak tests or a transom replacement and wanted your expert advice. I don't know what to do about the cut section, apparently it needs to be cut that low to allow for the prop on the motor to sit low enough, so I would need to find that aluminum trim cap material somehow I guess. I will start posting pic's with more questions. Thanks for any help, much appreciated.
Ok, I have more pics but from what I can tell, this shouldn't be hard to replace? It looks like the plywood could actually slide right down between the inside and outside sheets of aluminum. From what I've read on this site, I should use (3) 1/2" pieces of plywood instead of (2) 3/4" ?? Or does it matter? Also, dumb question I guess but where do you get the drain holes? I'll check iboats first, just not sure what you would call them.
