86 Searay Weekender 350 Merc 230hp
CandV
Hello, This is a question regarding loss of power. It started a couple of days ago and has got me worried.I fish for Muskie and spend much of my time idling (trolling). The other day I almost got caught by a storm but made it back in time, however, on the way back after about 25 mins at 3200 rpm 30 mph, The engine started to bog down. I slowed down and checked fuel,temp, oil pressure ect. all look normal. So off I went again. Same thing. I found that I if I stayed just off plane and around 2000-2200 rpm I could chuge along. Need some advice guys!!! C :eek: apt Chris
John Boelte
Re: 86 Searay Weekender 350 Merc 230hp
Water in the gas, bad gas? Try running some STP or HEAT (gas drier, essentially alcohol to absorbe the water). Also, check/replace your fuel filter. Check cap, rotor, plugs, wires, points, etc.
It's a Fuel Issue....<br />Replace the gas filter....<br />Check the fuel pump.....<br />Check the carb....<br />Tank,....Lines....etc....<br />I'm betting on the filter....
magster65
I think bondo's right. Check the little fine screen in the carb. inlet.
