Hi All I recently purchased a 86 challanger bass boat with a 87 dt 115. It starts up great at the highest idle setting, and has no problem running at idle. some times It seems it wont accelerate to full rpm and some times it will. this past weekend it was running fine for most of the day and then the last time I went to start it up and take off it bogged down and the fastest I could get it up to was 30mph usually its arround 45 to 50. It sounds kinda weak and the boat will not plain out very easy. I sprayed out the carbs a little and checked all the throttle linkage. while I had it running I lightly sprayed the carb bodies and the motor would bog down, I was thinking maby a vacume leak but their arent any vacume lines. I changed out the fuel filter aswell. Im kinda puzzled any ideas?
some times it runs great and some times not
