'86 Volvo impeller question
bstringer820
Hi I have a 86 volvo penta project boat. It is a aq131a 4 cylinder. When I got it running notice that its not pumping water. So i checked the ipmeller looks good so i check if impeller is turning but its not there is a slot at the end of the impeller shaft but when i went in deeper i notice that theres nothing for the slot to slide on its just a bolt head and a rubber sleave maybe its missing a slot pin so if anybody could help me on how this system is suposed to work i would be most grateful thanks
jerryjerry05
Pics??? They would help.
​How are you supplying water?
The drive has a 1/2" hole on the bottom that needs to be plugged or it won't pull water while on muffs.
