This boat is my uncles and I'm trying to help him get it going.
Last year it overheated on him.So he checked the raw water impellar and said it was shot, fins were pretty much gone on it. After putting new one on it continued to overheat. Since then he hasn't messed with it. I've done some reading on this motor and seen about using muratic acid for cleaning the heat exchanger out. But like to know little more how to before attempting that. Also how should I go about back flushing the raw water? I'm thinking if the impellar was chewed up as bad as he says it was then the chunks of impellar could be clogged in there still causing it to over heat. Appreciate any help, Thanks
