Casco Bay Outrage
- May 31, 2006
- 112
After lurking, here is my first post.<br /><br />I have done a search here and don't seem to see the answer.<br /><br />I have a '86 Yamaha 90 2s that has been great. Replaced water pump several weeks ago. Tell tale is strong. <br /><br />Now when the boat runs 3k or higher, get an overheat alarm (steady tone). At lower speeds, alarm stops.<br /><br />Boat is trailered but is used in salt water and flushed.<br /><br />I reviewed Yamaha parts diagram online. T-stat removal/replacement appears to be very straight forward. Is it straight forward?<br /><br />Should I replace the gasket, spring, valve and grommet or just t-stat?<br /><br />Thanks!
