Re: 87 15HP Johnson has no water from telltale
Hi Tonycliffy and welcome to the forum.<br /><br />Let's do basics. First, when running an outboard out of the water, use flusettes or a drum that will put the water over the water pump. A bucket just don't get it. Look for the mating line between the lower unit and mid-section. The water pump sets right in here. Also, the water pump MUST be under water to work. Be carefull not to over rev the engine. About 2grand is plenty when running the engine out of the water. If you have the engine on a flushette or in a drum and you still don't get water from the tell tale, that's the pee hole, then you probably will need to replace the water pump impeller. Generally, even though the thermostat may not work, you can still get water from the tell tale. If you know the pump is good and she still gets hot, replace the T-stat. Keep us posted on your progress. OH! Almost forgot. If you're in to do it yourself type stuff, get a manual for the engine. I-boats have the generic types that will help. Seloc is probably the preferred manual. But an OEM manual will do you much better. Good Luck!
