hcwalker81
- Jul 6, 2011
- 15
With trim all the way down I get to around 3200 rpms. When I start trimming giving gas the tach will jump to 4500 to pegged out. Based on the engine sound and speed it should still be around 3800 at this point.
As soon as this happens it starts skipping too. I am thinking bad coil? Would this cause the higher rpm miss and the tach to act up?
I have also noticed a pretty big hole on the exhaust bellows right out of the transom. Would this cause this problem?
Boat has new propeller, points, cap, rotor, plugs, wires.
