dannyboy63
- Jun 23, 2013
- 6
Greetings from the newbee. Motor runs fine but boat is very slow.....The specifics are as follows: 21', 3100lbs, 4 Winns candia 200 serial#(4WNMX558C7 87) deck boat with mcm 200, 305 cid v8, max rpm 4200 to 4600. If it helps the transom serial# is 0b693315 but havent found any specs on it. The Drive unit serial # is 0b680324 but cant find the ratio on it. The prop is a Quicksilver 48 73980 A5 19P, not sure how to figure the diameter. I would like to pull a couple of skiers so I could teach my son to ski...he's 6'7" and need to pull his bug ole butt up...I would like to cut to the chase and just get some suggestions on which prop will do the job.....thanks in advance.
