87 bayliner engine swap
nyfireman
Im hoping for some good news here. I have a 87 bayliner capri that im restoring with a 2.3 ford motor that has a cracked block. Someone told me i could swap to a 3.0 motor. Not sure if he is just trying to sell it to me or will it work. Will a 3.0 bolt right in? If so will i have any problems or little perks that pop up? Thank You !!
Bob_VT
Re: 87 bayliner engine swap
Your best source for that is Don S one of the Moderators who is an i/o guru... I will move this to the I/O area :)
Welcome to iboats!!
proshadetree
Only if you find a complete swap.3.0 is a gm engine it needs all the parts to swap to that ford powered boat.As far as wiring in the old boats are about the same as in you dont have to worry about ecms and such.Id just find a ranger or mustang engine and swap it for marine use.Or a service block for yours.
mkast
Save yourself a lot of headaches and money, replace the 2.3.
The exhaust system alone will cost a bunch.
