87 bayliner with force 125 motor falls when rasied.
Scooter29
When I trim up the motor is wants to fall back down slowly. Do I need a new pump or can I fix it? There is no signs of a leak. Thanks Chris
revertmastec
Re: 87 bayliner with force 125 motor falls when rasied.
scooter ,<br /><br /> Hello, Sure you can fix it. Get yourself a manual and a o-ring set for your cylinders and go for it. Just follow the directions in the manual it will tell you how to replace the seals.<br /><br /> Good Luck
Scooter29
Revertmastec,<br />I wasnt sure that was the problem. I read some posts about the pump being bad or seals in there. Thanks for the advice.
clanton
It is almost always the pilot check valves in the pump. Search Force 125 T T, Force 125 tilt trim
Scooter29
Clanton,<br />Thanks I have read many post where you talk about removing vavle. I have the snap ring style. I'm going to try to remove it now. Thanks
