charlieforker
- Jul 5, 2005
- 9
I just finished installing a new waterpump kit, thermostat, and carburetor kit as well as a lower unit on a 1987 Evinrude 25hp that hasn't ran in about 10 years. I had to remove the starter assembly to be able to remove the carburetor. As an oversight I didn't fully tighten a ground on one of the posts on this assembly. <br /><br />I have read elsewhere that it is detrimental to electrical systems to disconnect a running motor from the battery. Well this motor started right up after I finished all the assembly and ran rough as expected. As it was running I noticed the loose ground wire, shut it off and tightened the nut on the post. It started back up and ran pretty well considering it hasn't run in a very long time. This didn't last very long.<br /><br />The motor shut off and would not restart. I checked both plugs for spark and had none. I went through all wires and traced the kill wires and everything looks fine. I am going to pull the flywheel off today to see if a bug has blocked the ignition. If I dont see anything out of the ordinary. I dont know what to do.<br /><br />Please help with any suggestions as to what it could be. I think its very strange that it started and ran, then has no spark at all. Sorry for the long post and thanks for your help
