greasemonkeyjm
- Jun 20, 2003
- 20
I have a 87 48SPL model E48ESLCUS iI bought llast Week on a pontoon boat.It has been sitting since the first of the year, anything before that I'm unsure of. Engine has 125 pounds compression on each cylinder, spark on both will jump across 7/16 gap.I'm running 50:1 mix, has the non adjustable carbs, it starts fine, but tries to die if you let it sit at idle,and when you put it in gear, you have to go ahead and throttle up a little to keep it running but after you come up from idle it throttles to WOT smoothly with no stuttering or hesitation, but at idle the rpm will run up and down, it doesnt have a tach, but i would say idle is around 650 or so, but it climbs as high as 3,000 rpm's, high enough that i quickly shut it down to keep from slinging it apart. I know that a linc and sync may would help the dying when coming off of idle but I don't see where that would have an effect on the erratic idle speeds I tore into the carbs and they look clean, but I have them soaking as we speak. spark plugs has a good color to them and just a touch of wetness after the engine has set for about 1.5 hours after a run.
thanks
Bo
thanks
Bo
