After reading every post I could find on Force 125 Trim Units I decided I had the guts to try to replace the pilot valve seals in the pump valve body. I thought I had executed the repairs prefectly. However, after tilting the motor up and down several times the motor suddenly stopped tilting down. Anyone recognize this problem?<br /><br />My tilt unit is the one with the snap rings. When changing the pilot valve seals I also unscrewed the five bolts on the top of the pump (two normal looking bolts and three hex bolts). I carefully pulled off the cap and underneath were two springs and for bearings. I am fairly sure that I put everything back where it is supposed to go but would like to varify the location of the smaller spring. Moving counterclockwise from the largest bearing and spring you will arrive at the first small bearing. Is this the one the small spring goes upon?<br /><br />Thanks for any help.
