BABA BUOY
- Jul 17, 2011
- 5
i have a new-to-me 87 force outboard that im trying to replace the propeller on. i took it to a marine supplier who sold us a prop that did not seem to fit the same as the previous one. after the supplier suggested removing the anode it seemed to fit fine. put it in the water and threw in reverse and the prop loosened the nut and the prop nearly came off. went back to the store, major apologies from the owner, put a slightly different prop on it, WITH anode, and with missing washer behind the nut. put in the water again, reverse went fine, then in forward started hearing a grinding sound (like metal on metal). went back to the dock and the prop was loose again.
seems all the research ive done leads me to one answer: original prop was discontinued and i will have to use something else.
any insight as to why the nut wont stay on? there is no cotter pin, just a locking nut and washer. thrust washer was in place both times.
