Hello,<br /><br />My motor wouldn't start after sitting thru the winter. After some routine tests, I finally took it to a shop. Initially, I was told that the carbs needs some hoses replaced and some rebuild required. This was to be about $500. When they tok it apart, I was told that these brass ports were cracked. I think these are outake from the carb? These ports do not come out, so the shop is telling me I'm looking at over $1000 now for two new carbs with labor. I'm thinking these were probably cracked for a while, and I'm wondering what the down side is of leaving these the way they are. This boat is worth about $1800 or so running, so I don't know if spending the money is worth it.<br /><br />Can someone explain this crack and affect on performance or life of the engine?<br /><br />Thanks,<br />Dave
