'87 MerCruiser 3.0 stalls when backing off throttle
nicksfans
Hi all! I'm a long-time reader but first-time poster. Anyway, I have a 1987 V-Master bowrider with the 3.0 MerCruiser w/ Alpha Gen I drive. I've owned this boat almost four years, but for the last two I've had a persistent issue that I can't seem to resolve.
When cold, the engine starts and runs with little or no hesitation. After a minute or two of warming up, it'll idle, accelerate, cruise, and idle again smoothly. However, after cruising for about 20 minutes and then backing the throttle down to ~1500 RPM or lower, the engine stumbles and stalls within 10 seconds.
When this happens, the ignition coil and fuel pump are both quite hot to the touch, and the engine is extremely difficult to restart. I have to wait several minutes, pump the primer bulb (added by a previous owner), open the throttle almost fully, and crank it over several times. On the first few attempts, the engine either doesn't fire or runs briefly and dies, sometimes backfiring. Eventually, it will rev up and stay running as long as I keep giving it throttle. If I'm in open water, I do this process with the boat in forward gear, so when it finally revs up, I can continue on my way. As long as I don't back off the throttle, it'll continue cruising just fine.
A few things worth noting:
1) When the engine stalls and I squeeze the bulb, it seems like the carb bowl is NOT full. The bulb isn't stiff, and it sounds like there's additional fuel entering the carb as I squeeze.
2) HOWEVER, spraying starting fluid in the carb doesn't help the engine start. If anything, it makes things worse. My amateur knowledge tells me it's flooding, but how would it flood with seemingly no fuel in the carb?
3) Cooling system seems fine, but to be clear, I'm no marine mechanic. What I do know is that when I run the boat on muffs, I see a substantial flow of hot water out of the exhaust port at the transom, so there's obviously water flowing through the hot engine. When cruising on the lake, the temp gauge never exceeds around 140F, but I don't trust it completely.
4) The boat has always been a little hard to start after warming up fully and then sitting for an hour or so. I had always attributed this to vapor lock, but it wasn't enough of an issue to bother me. It certainly has NOT always shut down when backing off the throttle, like it's doing now.
This trouble seemed to start after I rebuilt the carb due to issues with the accelerator pump (which is no longer an issue). However, I'm borrowing my friend's almost-identical boat with the same engine for the purpose of swapping parts over to troubleshoot. When I swapped my friend's carb onto my engine, there was no improvement.
Here's everything else I've tried, not necessarily in order, to no avail:
-- Opened and inspected the carb at least twice after rebuilding.
-- Checked timing and dwell.
-- Replaced plugs (gapped to spec) and plug wires.
-- Changed from points to Pertronix. Initially used 3-ohm coil with resistor wire bypassed, then tried two other 1.5 ohm coils with resistor wire reconnected. Pertronix module was always connected directly to 12V per instructions, NOT after the resistor wire.
-- Replaced mechanical fuel pump with the one from my friend's boat.
-- Installed a marine electric fuel pump instead of the mechanical one (I was sure this would help; it didn't!!) The electric pump is mounted to the port side of the block, just behind and below the alternator, and wired to come on with the ignition.
-- Replaced questionable electrical connectors under the helm, thinking voltage to ignition system may be low.
-- Checked engine temps with IR thermometer immediately after it stalled on the water. Hottest I saw was ~210F on the lower starboard side of the engine block, which to me, isn't alarming. Most other areas of the engine were ~150-180F.
-- Checked condition of circulating pump (no obvious issues there).
The two things that seem to help are:
1) Running the boat without the engine cover (doghouse). For some reason, the breeze blowing across the engine seems to make a difference.
2) Continuously squeezing the primer bulb while backing off throttle and idling afterward. This makes it run much longer before stalling, or sometimes not stall at all.
Here are my theories:
1) Something is wrong with both my carb and my friend's carb (both are Mercarbs) that's causing a flooding condition when coming off the throttle, only when the engine is hot, and this is what empties the bowl. (My friend's boat needs some other work to be lake ready, so I can't just take that one out to compare.)
2) My engine is running hotter than it should for some reason, boiling the fuel in the line and causing vapor lock at idle (less fuel flow than during cruising). I'm considering installing a mechanical temp gauge just to confirm.
Is there anything I'm missing? I'm tearing my hair out, but I like this boat and I don't want to give up because of a seemingly simple problem. Any suggestions would be greatly appreciated!
jjcarroll1
My guess would be to replace fuel lines. Sounds like you've done everything else.
itsathepete
210 on engine block is way too hot. Check your thermostat in a pot of water on the stove with a thermometer to see when it opens. You also may have blocked lines or crap in the cooling system. The engine should not start in gear. Someone has monkeyed around with the electrical system. Figure that out and fix it. Previous owner installed primer bulb to work around a problem instead of fixing it. Check your entire fuel system including vent hoses and antisiphon valve. Hot electric fuel pump may be due to underhood temp or having to pull fuel too high from tanks. They are cooled by the fuel flowing through them and pulling fuel uphill limits performance and flow. Your boat has a case of jerryrigitis. Good luck
dubs283
You need to get rid of the primer bulb. That is merely a restriction in the fuel supply and helps nothing in your situation. Go back to the mechanical fuel pump, 3.0 carb motors never had electric fuel pumps oem. Inspect the entire fuel system from tank/pickup to carb. Check fuel pressure and vacuum at varying rpm/load
As far as temperature, yeah nothing too terrible but as stated 210 is too hot. When was the last seawater pump r and r along with full drive/transom inspect and service?
nicksfans
Thanks for the replies! This is helpful. Here’s some more info:
— Fuel lines from tank to engine are 2017 or newer. I also used a hand vacuum pump to check how much vacuum is needed to pull fuel from the tank. I don’t remember the exact reading, but my boat actually required less vacuum than my friend’s boat, so I didn’t suspect a restriction in the fuel line, pickup, or antisiphon valve. I can hear the valve rattling a little when I suck fuel through using the vacuum pump, so I don’t think it’s stuck. This is just with the boat on the trailer, but I don’t see how it would be different on the water.
— Fuel tank vent isn’t clogged; I know because if I fill the tank too much too quickly, some fuel comes out of the vent. I’ve learned not to fill it to the brim. Also, when the engine stalls, loosening the fuel cap doesn’t seem to help get it going.
— Thermostat and raw water impeller were replaced in 2018 shortly after I got the boat, and impeller was replaced again less than two years ago. Both times, the old impeller still looked OK (no missing fins). I also haven’t noticed any reduction in the amount of water coming out of the exhaust since I bought the boat.
— Drive was off in 2019 because the engine coupler had stripped and needed replacement. Replaced gimbal bearing, greased splines and u-joints, and checked engine alignment at this time. Also had a shop replace the input shaft seal on the drive because I found gear lube in the u-joint bellows.
— When I removed the circulation pump for inspection, the block and other water passages were visibly rusted inside but nothing looked clogged. I did NOT check for a blockage in the manifold, though.
I’ll try the suggestion of checking the thermostat in a pot of water first; I suppose it could be defective. I also probably will try running with a mechanical temp gauge, just to see if it matches the original electric one. I’ll be back with an update!
P.S. @itsathepete, I know it shouldn’t be able to start in gear, but that’s been keeping me from getting stranded. If I can get this stalling issue fixed, I’ll be sure to look into that.
dubs283
Its fine you can draw fuel out of the tank with a hand vacuum pump. Makes no difference if it's easier than your friends boat, we're talking about your boat. Vacuum test on the fuel system needs to be performed with the engine running, this tells you what the pump is drawing and can draw. You also need to check fuel pressure, otherwise everything is speculation. Just assuming things are okay without verification means nothing. As I said you need to abate the primer bulb, it's a restriction that was never intended to be used on a sterndrive engine.
As far as the cooling goes are you using oem impeller/housing kit? Have you ever replaced the pump base and gasket?
nicksfans
Well, I tried some more stuff over the weekend, including going out on the lake again.
--Thermostat seems fine; it opens under hot tap water which is 140-150F tops.
--Water flow does not appear to be an issue. I ran it with the lower unit in a tub of water, and then on the lake. Water temperature (according to the secondary temp gauge I added) was always below 155F with the engine running. Video here:
(To answer your question, @dubs123, I did replace the impeller, housing, and pump base/gasket last time. It was not an OEM kit though.)
--I realized the fuel line had NOT been replaced all the way back to the tank. There was a section of original fuel line several feet long hooked up to the tank, and the newer line was spliced onto it. The old line wasn't even clamped to the tank fitting, just shoved on. I replaced it and added a hose clamp. This did not fix the stalling issue, but it seemed to be less severe this time around (it didn't happen as often, and the engine was easier to get started again when it did happen).
I guess the next step is checking fuel pressure and vacuum. I may (and know I should) check the fuel pickup in the tank, but it looks horrible to remove so I'm not looking forward to it.
